->ALL<- Questions and Answers about Broadcast Tv Reception and More.
Going on down the list past KPXM.
This is what is on these Tv stations/channels.
K16HY-D Real UHF channel 16 , EWTN Catholic Television.
K25IA-D Real UHF channel 25 , TBN Trinity Broadcasting Network.
WDMI-LD Real UHF channel 31 , Virtual channel (62.1) , Daystar.
K33LN-D Real UHF channel 33 , 3ABN 3 Angles Broadcasting Network.
K43HB-D Real UHF channel 43 , HSN Home Shopping Network.
If the Tv stations/channels listed above are not received at the current antenna height , and you will like to receive them , then a higher antenna height is required.
Any Tv stations/channels below K43HB are un receivable with out going to a much higher antenna height.
