Old 15-Jul-2012, 2:39 AM   #7
Electron
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
Texas is real big on metal backed insulation in the the attic that reduces and reflects Tv transmissions.
Also the western part of the USA is real big on stucko / Wire walls , the stucko Wire does a good job of reflecting Tv transmissions.
Install a Winegard HD7080P antenna , Above the roof up high aimed at about 243 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
The HD7080P antenna is a Heavy Duty constructed antenna.
Much more so then the HD7015
Use no preamplifier.
----> How Many Tv,s Are/Will Be Connected?? <----.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirtect.com , http://www.amazon.com.
The Tv/s Must scan for the Broadcast Tv Channels sometimes named the , 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO Not scan for cable tv channels.
----> How Many Tv's Are/Will Be Connected??<----.
