Thread: New to OTA
Old 14-Jul-2012, 7:21 AM   #10
Metallo
Originally Posted by Electron View Post
Nothing from Maine will be received unless the antenna can be mounted higher , make 2 more posts with the antenna at 60 feet and 100 feet. The local tv stations/channels will be received with a Winegard HD7080P antenna mounted above the roof at about 25 feet above ground. Aim the antenna at about 168 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html Here are places to buy antennas and antenna mounts and coax and etc. in Canada. http://www.saveandreplay.com , http://www.trentondistributors.com
Hi,
wouldn't the Winegard HD7084P more appropriate in my case instead of the Winegard HD7080P ?
I was looking at the VHF reception range, approximately 80 miles for the 7084 Vs 50 miles for the 7080.
The distance from Fredericton to Mount Champlain (CTV is the hardest station for me to get) is about 70 miles.
Also, will I need an amplifier or shall I first try without and then get it if needed?
Also, coming to the antenna sizes, I read width: 110 in., is it indeed so large or am I missing something?
FYI, yesterday I posted this question on digitalhome forum too but did not get any reply yet.
Thank you!
Alex
Metallo is offline   Reply With Quote
