Old 14-Jul-2012, 12:43 AM   #27
energyzer
Originally Posted by Electron View Post
It is all your choice , You do what ever You think is the best.
To reduce confusion to a minimum. Here is the information.
Your location has receivable Tv stations/channels in ALL 3 Tv bands.
VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
I recommend install a Winegard HD7082P , ALL band , ALL channel antenna aimed at about 240 degree magnetic compass.
Here are some Strong and Sturdy above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.htmlhttp://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box.
Here are places to buy antennas and etc. , http://www.solidsignal.com . http://www.winegarddirect.com , http://www.amazon.com.
I listed All the receivable Tv stations and channels.
With the HD7082P antenna installed and used to receive the Tv stations/channels and programing.
There is one programing channel that will possibly not be received and that one is , The Live Well Network.
Notice the words -> possibly not received <- .
If after installing and using the HD7082P antenna , the Live Well Network is not received and you will like to receive it , then install a rotor.
As to the C5 and DB4e , the C5 comes with a combiner that combines the C5 and DB4e on to one coax , no A/B switch required.
I will not provide any more information.
These opinions can go on for ever and ever.
Wow, I appologize if I've upset you for some reason. I'm only trying to make a quality decision. To do this, I wanted to tap into a source with a lot of knowledge, namely, TV Fool. I do ask a lot of questions, but only because I want to be sure. I'm sorry for the inconvenience I cause you. If you look through the thread, I would hope you can see why there is some confusion.....you say I don't need a rotator with the 7082 pointed at 240*, while Signals Unlimited is suggesting to get a rotator. Gosh, I'm sorry, I didn't mean to offend you, and appologize for that, I'm only trying to figure this out.
energyzer is offline   Reply With Quote
