------->As I under stood it you already have the C5 and DB4e antennas.<--------
I am evaluating the use of one antenna , will return shortly.
Well Ok , further evaluation shows that currently all the programing can be Received with the C5 antenna.
The C5 is really a VHF high band antenna channels 7 thru 13 antenna.
The C5 will receive the VHF low band channels 2 thru 6 if the signals are strong.
The C5 will receive the UHF band channels 14 thru 51 if the signals are strong.
A Much Better Solution for reception with one antenna is a Winegard HD7082P antenna aimed at 245 degree magnetic compass.
The HD7082P antenna is -->designed<-- to be a All Band Antenna. VHF Channel 2 thru 6 , VHF channels 7 thru 13 and UHF channels 14 thru 51.
A Much Better Solution is the HD7082P All Band Antenna.
