->ALL<- Questions and Answers about Broadcast Tv Reception and More.
I find watching the signal strength meter to be more interesting then many Tv programs.
But then I am more interested receiving Tv stations , then being (entertained???) by the programing.
The Tv/s Must scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travcel through the air from the transmitting antenna to the receiving antenna.
Do Not scan for cable tv channels.
A antenna amplifier will most likely not be required for one Tv connection.
For one Tv connection use No splitters. Every time a splitter split takes place the signal strength is reduced.
No sense to reduce signal strength needlessly.
