Old 13-Jul-2012, 3:08 AM   #12
Seaboy
Originally Posted by Electron View Post
I am providing clear and straight forward information.
The VHF antenna upgrade kit is a antenna that is installed on the CS2 , for reception of VHF high band channels 7 thru 13.
It is not to improve UHF reception of the UHF only CS2 antenna.
Your location has receivable VHF high band channels.
KCPQ-DT channel 13 FOX.
KSTW channel 11 CW.
KCTS-DT channel 9 PBS.
K08OU-d channel 8 3ABN.
http://www.rabbitears.info/market.ph...&callsign=6381.
http://www.rabbitears.info/market.ph...callsign=66997
Electron,
Once again, thanks for your comments, as I know you have much to offer to the community. Your post #6 was clear, and to be extra clear, I do appreciate all your comments and intended no disrespect in my first response to you (post 3). I am just trying to focus on the desired channels in my original post, and I guess I can summarize now that you mean by adding a receptor, I should be able to receive KSTW CH 11.
Also, FWIW, I agree and have tried actually on my first attempts to get a compromise with Az in an effort to collect signals from the clusters to the NW and the cluster to the SW; however, after poor results of the NW receptions, I switched my methodology to specifically concentrate on the desired channels in the NW cluster (outlined in my OP).
Thanks again for your insights.
Seaboy
Seaboy is offline   Reply With Quote
