Old 12-Jul-2012, 11:24 PM   #2
If you have a wood framed roof with composition shingles and no metal, (sheet or foil) that would block the antenna's 'view', then an attic mounted antenna could work. Still, when the roof is wet and especially if loaded with snow, expect more signal loss.
I would try this with an Antennacraft HBU-44 or HBU-55. If you get unreliable reception in the attic, the Antennacraft models are easy to re-fold, making it possible to move them outside without damage.
