Old 12-Jul-2012, 10:39 PM   #6
Electron
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
The Bigger/Larger a Tv antenna is the more directional the antenna is in the forward direction and the more antenna gain the antenna has , that good for reception of weak Tv signals.
However more forward reception means less reception at angles to the antenna and back of the antenna.
Less reception at angles and back of the antenna is not good for your reception situation because the receivable Tv stations/channels 7 thru 51 are all around the compass.
The ANT751 is a small almost non directional antenna that does have some small forward gain but also receives well in other directions.
The small ANT751 channels 7 thru 51 antenna it is easier to find a compromise aiming direction that will receive strong signal strength stations in different directions , like at your reception location.
The YA6260 is a big forward directional antenna that is for reception of VHF low band channels 2 thru 6.
