Old 12-Jul-2012, 8:19 PM   #21
Originally Posted by medic7603 View Post
Ok, update. Happened to find a 2 way splitter with power pass through on both ports. Hooked it up and went from getting full channels downstairs and nothing upstairs to full downstairs and a few(not nearly enough) upstairs. That being said the power injector is downstairs and not upstairs, does that make a difference? Would it work better or worse to have the 2 way splitter with single power pass through? I'm just wondering if it's not injecting the power back upstairs or something. I'm at a loss here now and want to get this done as soon and frankly as economically as possible.
If I need to get a new splitter I was thinking maybe this one?
http://www.amazon.com/DIRECTV-SPLIT2...ter+power+pass
Yes/No?
You seem to be passing power to the amplifier... good, or I'd expect virtually no reception at all. But, depending on the design, putting DC power into a TV tuner may saturate the core of an input transformer, making it fail to pass much signal. (Don't use a splitter that allows DC power to back-feed into the tuner... ie. use a splitter with power pass on only one port.)
The splitter from Amazon will work just fine. It has more bandwidth than you need, but the price is very competitive (I would avoid satellite grade splitters only if they cost more than OTA/CATV grade.)
