Old 12-Jul-2012, 5:54 PM   #4
pico
Thanks for the quick reply. I see what your saying there. I had already rotated and scanned the ANT751 in that direction 346 degrees did not pick up. I must say I also have a some trees to go through but the signal strength may be the first culprit as you say. Right now I have three tv's and mostly one is on and sometimes two at most. I get all channels great pointing antenna about 145 degrees.
I know that both KCWX Real channel 5 , Virtual channel (5.1) , is MyNetwork and This Tv and they show up on Titan tvguide broadcast zip code 78212 as virtual ch 2.1 and 2.2. The local cable services only show 2.1.Are you saying that this Real Channel 5 would be broadcasting both of these. Right now I don't get either one.
pico is offline   Reply With Quote
