Old 12-Jul-2012, 3:43 PM   #6
SatteliteSucks
I looked at both of the antennas. Look like good options. I'm not sure I care about picking up KMOS, an omni directional wouldn't be able to pick up the majority of the major broadcasts which 8 of I believe were in HD. So going with a single amplified directional antenna should get me a good set of HD channels so long as you guys think they will be reliable/clear signal. I was thinking of using one of these to use my computer or build a HTPC and transmit the TV throughout the house with IP.
Thoughts?
The house is only a 2 story but it has a pretty high roof line. I think it would probably be around 35. I could mount the antenna as high as I could in the attic?
Thanks for all of the help!
-Ryan
SatteliteSucks is offline   Reply With Quote
