Old 12-Jul-2012, 10:01 AM   #4
KMOS-DT Real UHF channel 15 PBS is the opposite direction at 107 degree magnetic compass.
The signal strength is strong at 42.2 NM(dB).
If KMOS is not received with the HD9095P antenna pointed at 284 degree magnetic compass.
And you will like to receive KMOS then install a second HD9095P antenna aimed at about 107 degree magnetic compass.
The 2 HD9095P antennas will not be connected together on to one coax.
The 2 separate antennas will have separate coaxes all the way to the location of the projector tuner and be connected to a remote control A/B antenna switch , http://www.radioshack.com , # 15-1968 , or , http://www.mcmelectronics.com , # 32-4425.
Or the 2 separate coaxes from the antennas can be connected to 2 separate tuners.
