Old 12-Jul-2012, 2:47 AM   #2
A Channel Master CM3022, http://www.channelmasterstore.com/Ma..._p/cm-3022.htm would be a good option. It's more directional than a panel antenna with the same gain which in your case would be desirable given the edge path signals listed on your report.
If your attic/roof construction does not include metal or tile, try the install there. For best results, roof top mounting is recommended.
Take a look at http://www.rabbitears.info/market.php. I expect all the major networks will be in HD (720p or 1080i). Expect additional SD feeds as well. I would expect you to be able to receive the top 11 real channels listed on your report. Most stations broadcast two or more programs in the their allotted bandwidth.
Last edited by GroundUrMast; 12-Jul-2012 at 3:22 AM. Reason: fixed rabbitears link
