KCWX has a construction permit to transmit on channel 8 but has not done so yet.
So that leaves KCWX channel 5 to receive.
The ANT751 does not have the capability to receive channel 5 unless the signal is real strong.
The ANT751 is designed to receive channels 7 thru 51 the best.
The channel 5 signal is on the weak side.
My suggestion is to install a antenna that receives channels 2 thru 51.
Install a Winegard HD7000R antenna aimed at about 346 degree magnetic compass reading.
There is another way to do it using the ANT-751 and a second antenna , --> But first tell me , how many Tv's are/will be connected. <--.
Also my research shows that.
KCWX Real channel 5 , Virtual channel (5.1) , is MyNetwork and This Tv , not the CW as the tvfool channel list shows.
And KMYS channel Real channel 32 , Virtual channel (35.1) is the CW and Cool Tv, not MyNetwork as the tvfool channel list shows.
