Old 11-Jul-2012, 8:41 PM   #7
medic7603
Thanks for all that it helps. I attached it to the second cord going downstairs and connected it to a new vizio tv I just picked up. It receives both the channels I couldn't grab with the other one(a Philips), but the one channel is choppy and I imagine a greater height would be good. I'll try that next. I'll also try the power passing splitter on the outside and the injector inside that way I can keep the injector inside since I found out its not approved for outdoor use.
Does that sound like a good idea. Cable from antenna to power passing splitter to the two cables indoor to the injector(up or downstairs cable? Or both?) and then to tv? Thanks again for helping this newb.
medic7603 is offline   Reply With Quote
