DTV/cell phone reception advice and products
The signal is strong but due to the refraction from the near by hill you are most likly in a multipath situation. I would try moving the antenna up 12" at a clip while moving left and right around 20-30 degrees from dead aim at a time. Somewhere in that range and within three feet you may produce the channel. If not you may need an extra 10 to 15 feet of heigth. It's there...somewhere!
If there is strong FM near by try an FM trap before you try the above.
