With the antenna aimed at about 20 degree magnetic compass , that will put KBTC , K47LG , KCPQ , KTBW , at the back side of the antenna.
Those Tv stations transmissions are Very Strong and will most likely be received even though the UHF reflector screen is on the antenna.
If as in - IF - the stations are not received , then remove the reflector screen.
By removing the reflector screen the CS2 will receive in 2 directions , the front of the antenna and back of the antenna.
