Just to be sure...
From the point of view of the transmitting antenna, the elements of the CS2 should appear to be the number eight { 8 } not the symbol for infinity { ∞ }. The reflector screen is behind, farthest from the transmitter.
Laying the antenna on it's side will reduce it's ability to receive signals.
When you need cleaner signal, more signal, etc., additional mounting height is usually the best solution... though often the most difficult and costly.
