Old 11-Jul-2012, 6:01 AM   #2
Get the VHF antenna upgrade kit from http://antennasdirct.com , and install it on CS2.
Aim the CS2 with the VHF antenna upgrade at about 20 degree magnetic compass.
KBTC-TV 27 PBS , K47LG-D 47 CBS and RTV.
KCPQ-DT 13 FOX , KTBW-DT 14 TBN.
Are Strong signal strength and will most likely be received through the back of the CS2 with the reflector Screen in place.
If not then remove the reflector Screen from the CS2.
Mount the antenna above the roof in a manner that the roof does not block reception.
It is also a good idea to mount the antenna at a location that has the least amount obstructions such as trees and buildings and etc. .
Can find what programing is on a Tv stations/channels by typing variations of the - call sign - in the Google search box.
Example: , k47lg , k47lg-d , k47lg tv , k47lg-d 47 , k47lg 47 , and so forth.
The 2 main information sites that contain practical and useful information that will pop up are , wikipedia and rabbitears.info.
