Old 10-Jul-2012, 8:34 PM   #4
I believe the signal from KCWX (CW network), real channel 5 is receivable. When I run the numbers though, the CS600 with no amplifier, UVSJ, cables and splitter starts to look like it barely gets the job done.
25.6 dB (NM in the air) - 14 dB (Low-VHF Noise Correction Factor) + 2.3 dBd (Antenna Gain) - 7 dB (Cable, Splitter & UVSJ Loss) - (6 dB Tuner NF) = Net NM of 0.9 dB.
A Net NM under 10 dB is begging for drop outs and loss of signal.
You'll get more reliable results if you opt for a larger Low-VHF antenna such as the Winegard YA-6260. On paper, adding a low noise preamp such as the Antennas Direct CPA-19 improves the situation as well. IMO, using the YA-6260 and CPA-19 would be prudent. Using both 'upgrades' pushes the Net NM up over 15 dB.
