DTV/cell phone reception advise and products
With the large antenna that you are needing to use, you also need a sturdy rotor. The Channel Master 9215 rotor is my recommendation.
Before installing hook it up and test run. Leave it set at the counter-clockwise end of rotation (000). Install it with the arrow on the side of the rotor and the antenna headed magnetic North. Use your TVF radar numbers to locate the stations.
