Old 9-Jul-2012, 5:50 AM   #5
Electron
->ALL<- Questions and Answers about Broadcast Tv Reception and More.
Your location has receivable Tv stations/channels in both the VHF high band of channels 7 thru 13 and the UHF band channels 14 thru 51.
For reception of the Eugene OR. Digital Tv stations /channels.
Install a Winegard HD7696P antenna that is designed to receive the Tv channels 7 thru 13 and 14 thru 51 , above the roof.
Aim the HD7696P antenna at about 160 degree magnetic compass.
For one Tv connected no splitter or amplifier is used.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.amazon.com.
To avoid signal overload resulting in bad reception I am not recommending a preamplifier.
KOAC-DT 7 PBS is a Very Strong signal and will over load a preamplifier causing bad reception on more then one Tv channel.
KEPB-DT 29 PBS to the south is the same as KOAC. http://en.wikipedia.org/Oregon_Public_Broadcasting.
And K14GW-D 14 is the same as KSLR-DT 31 to the south.
So no requirement to aim any antenna to the west.
