Old 16-Jan-2010, 1:24 AM   #18
andy.s.lee
Janitor
Originally Posted by herplace View Post
Even where it is there would seem to be more much more room to grow. I gues I should measure before I ask but have you all any suggestions for a good next size up?
Every attic is different. Some people have tons of room and others have hardly any room at all. The construction of the attic and roof can also make a big difference in how much signal can pass through the building material.
Do you think your attic has enough space to handle an antenna that is 10-14 feet long and about 9 feet wide? If you are fortunate enough to have a spacious attic, then maybe you'll be able to get a very large antenna in there and make it all work. If not, then a rooftop antenna might be the only way to go.
Best regards,
Andy
andy.s.lee is offline   Reply With Quote
