Old 9-Jul-2012, 4:36 AM   #2
Why not start with a fixed aim solution. An Antennas Direct DB4e will outperform the UHF functionality of all the HBU series antennas. Facing about 150° compass you'll do very well receiving the available UHF signals. An Antennacraft Y5713 pointed toward 167° would receive the two High-VHF signals on real channels 9 & 13... you might get lucky and see the signal from real channel 7 from the west. Combine the two antennas with a UVSJ followed by an Antennas Direct CPA-19 preamp.
If you want to pursue the Portland signals, I'd suggest a Winegard HD7698P. You could add a rotator to provide full use of that antenna. Regardless, I'd equip it with a CPA-19 as well. This antenna would need to be cables separately from the first array.
There are several ways to connect a multi-antenna system:
http://forum.tvfool.com/showthread.php?t=2882
http://forum.tvfool.com/showthread.php?t=820
Satellite system splitters which pass 5 to 2000 MHz on all ports are useable in OTA installs. Diplexers look quite similar but will block OTA frequencies on one or more ports. Matrix switches need to be removed.
Last edited by GroundUrMast; 9-Jul-2012 at 5:55 AM. Reason: Comments re. Portland antenna & Satellite system parts -- grammar
