Old 9-Jul-2012, 1:41 AM   #23
Billiam
Originally Posted by Electron View Post
I turned some numbers around.
Here is the CM3023 , http://www.channelmasterstore.com/Ma..._p/CM-3023.htm
The CM4248 and CM3023 are the same in that they are both UHF antennas.
My recommendation still stands. The CS600 and DB4e.
You mean transposed numbers.
The link to the Channel Master Store is for a new model of the CM 3023. It is NOT the same antenna as the link I gave to the antenna sold by Summit Source. The Original CM 3023 WAS an updated version of the CM 4248 Yagi which was renamed and slightly altered from the original CM 4248.
Did you bother to look at any of the links I posted regarding the original CM 4248 and original CM 3023?
