Every time a split takes place the signal strength of the antenna system coaxes is reduced.
If one Tv is connected use no splitter.
If 2 Tv's are connected use a 2 way splitter.
If 3 Tv,s are connected use a 3 way splitter.
If 4 Tv,s are connected use a 4 way splitter.
The CS600 has a wide reception angle for the widely spaced directions of the VHF tv stations.
The DB4e is aimed at the UHF stations.
The CS2 Complete is designed for VHF high band 7 thru 13 and UHF band 14 thru 51.
Not the VHF low band 2 thru 6.
The CS600 from Antenna Craft is designed to receive channels 2 thru 13.
The DB4e from Antennas Direct is designed to receive channels 14 thru 51.
Your location has receivable channels in all 3 Tv bands.
VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 , UHF band 14 thru 51.
