You can reuse the mounting (J-pole) that the dish is on... IF the OTA antenna will not touch the roof or other parts of the building - and - the antenna will not be aimed into the roof. Most satellite mounts are not on the north side of the building because they need a view of the southern sky. Satellite matrix switches and diplexers (which may look like OTA/CATV splitters) need to be removed so that OTA signal can pass.
Solar panels will pose a problem if they are in or close to the path from the antenna to the transmitter towers.
