Old 8-Jul-2012, 5:03 PM   #13
Billiam
WMEB TV 25 is a repeater of the VHF station. It is used to shore up the weak signal areas of the VHF signal. Since he is right on top of the VHF station, no need to obtain this one. The two translators programming may not interest him.
Redtiger. The best way to obtain the WFVX TV 22 or WMEB TV 25 would be to use the following antenna pointed at 58 degrees. The wider reflector has superior gain for channels below 30. I own one of these and tested it directly against the Antennas Direct 91XG and Antennacraft MXU 59. The Channel Master 3023 (carbon copy of the old CM 4248) is the best Yagi for the lower UHF channels. You may not even need a pre amp if you use this antenna for TV 22 or TV 25.
http://www.summitsource.com/channel-...le-p-6678.html
