Old 8-Jul-2012, 4:27 PM   #17
Originally Posted by 5u4 View Post
I have a Denny's Up 7 now about 11' above the ground & pointed at 165° true azimuth with 20' of RG6 direct to the TV. I have some trees next to my property which is the only obstruction I'm aware of. While I have good overall reception, I have some random drop outs & would like more solid reception. WXPX-TV 42 (66.1) ION seems to drop out more than some others, though they're all prone to occasional drop outs from time to time. What antenna would you recommend? Thanks.
http://www.tvfool.com/?option=com_wr...990072f6212aad
No SS meter on my set, but I did move the antenna due south & picked up one more channel, WFTT. It's a Spanish language channel & have little or no use for it, but maybe have a better overall antenna orientation? With a due south antenna orientation, I have room for just about any length antenna. With it pointed at 165° like it was, the rear of a long antenna would touch the roof of the house, but pointed due south, it won't. Thanks.
I agree, this sounds like multipath or tree induced interference, which is why I suggested that before replacing the antenna, other simple and inexpensive trouble causes be eliminated.
If needed, and if possible, relocate the antenna.
Only as a last resort would I replace the antenna. 'On paper' the UP-7 should be doing the job. If I replaced an antenna in good working order for theses symptoms, I would use a larger, not smaller antenna. I'd be trying to get additional directivity and gain, not less.
@5u4, has the aim adjustment solved the problem?
