If you only want to use one antenna this is going to be a challenging situation since you have some pretty strong signals in green and one weak signal on UHF. I just checked and WFVX TV is still piggybacked on WVII's sub channel. That being the case, you could get by with just the Antennacraft CS 600 pointed at 58 degrees and still likely obtain WMEB and WABI off the side since both signals are quite strong and only ten miles away. The only drawback to this is that potential for multipath exists. I am familiar with the topography of the Bangor area and the hills and trees could present an issue for WMEB and WABI. No pre amp will be needed.
