Old 8-Jul-2012, 2:55 PM   #4
Your location has receivable Tv stations/channels in ALL 3 Tv bands , VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51.
Install a Antenna Craft CS600 , VHF channels 2 thru 13 antenna , aimed at about 45 degree magnetic compass.
And install a Antennas Direct DB4e , UHF channels 14 thru 51 , antenna aimed at about 74 degree magnetic compass.
Connect the CS600 and DB4e together with a UVSJ = UHF/VHF/Separator/Joiner , Combiner , in a weather protected plastic housing sold by Antennas Direct.
Connect a Antennas Direct PA-18 preamp to the output of the UVSJ.
For one Tv connected use no splitter.
For more then one Tv connected use Holland Electronics Splitters , http://www.hollandelectronics.com , also available at , http://www.solidsignal.com.
For 2 Tv's connected use a HFS-2D , 2 way splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
For 4 Tv's connected use a HFS-4D , 4 way splitter.
The tvfool radar plot is showing the antenna height at 30 feet , how will the antenna be mounted at 30 feet??
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html.
http://www.palcoelectronics.com/pe300.aspx.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennacraft.net , http://www.antennasdirect.com , http://www.amazon.com.
