Old 8-Jul-2012, 3:35 PM   #3
signals unlimited
DTV/cell phone reception advise and products
The omni will not be enough antenna to do the channels out of your main group of stations.
Use an Antennas Direct CS2 Complete aimed to around 40 degrees magnetic, It will receive the group of channels to your Northeast including real channel 2, since it is a strong signal, and the High VHF real 7 and 13 at 2 degrees magnetic. Real channel 10 should also be received from the Southwest, but Fox 23 will not be received.
With one antenna and no rotor as requested, that is as good as it can be.
