Old 7-Jul-2012, 9:11 PM   #7
signals unlimited
DTV/cell phone/broadband reception advise and products
You won't be needing to surf the York stations.
The York stations are very weak and most likly will not be received. Maybe with a strong pre-amplifier, 47 and or WGAL 8. Another FOX and NBC.
If you use a Channel Master 9215, run it before installing, let it set at counter-clockwise end of rotation (000), set it and the antenna magnetic North. This will allow you to go straight to any channel location by setting the display to match the numbers in your TVF report. Store these settings and you can recall any location with a command on the remote. Kinda like surfing.
