Old 7-Jul-2012, 6:07 PM   #93
Tilting an antenna a few degrees can help in some situations. Don't expect dramatic results, just fine tuning the last bit of performance available.
Most antennas will perform the same if you turn them upside down, so long as they are still pointed toward the transmitter. A few designs may collect water if mounted upside down, be careful to avoid that situation.
