DTV/cell phone reception advice and products
Do you have a signal strength meter in your DTV menu? If so and the level is in the high range an antenna change may not help. The UHF part of the UP7 a corner reflector and very similar to the UHF part of some of the larger antennas. If you need more signal just add a pre-amplifier. I use the Winegard AP8700.
GroundYourMast recommendations for eliminating electrical interference may lead you to the problem.
Antennas Direct techs also have many tips on interference elimination.
