Old 8-Sep-2010, 2:55 PM   #2
Dave Loudin
You're on the right track, since you have stations on UHF and both VHF bands. You should consider the Winegard HD8200P, as it appears to have similar performance to the AntennaCraft HD1850, but costs a little less. You will need all the gain you can get. Also, you should tip the antenna a couple of degrees up from horizontal
You might consider a pre-amp such as the Channel Master 7777 especially if your cable run is going to be 50 feet or more.
