Old 6-Jul-2012, 5:40 PM   #17
http://www.fcc.gov/guides/over-air-r...ces-rule#links includes:
Q: What types of antennas are covered by the rule?
A: The rule applies to the following types of antennas:
(1) A "dish" antenna that is one meter (39.37") or less in diameter (or any size dish if located in Alaska) and is designed to receive direct broadcast satellite service, including direct-to-home satellite service, or to receive or transmit fixed wireless signals via satellite.
(2) An antenna that is one meter or less in diameter or diagonal measurement and is designed to receive video programming services via broadband radio service (wireless cable) or to receive or transmit fixed wireless signals other than via satellite.
(3) An antenna that is designed to receive local television broadcast signals.
In addition, antennas covered by the rule may be mounted on "masts" to reach the height needed to receive or transmit an acceptable quality signal (e.g. maintain line-of-sight contact with the transmitter or view the satellite). Masts higher than 12 feet above the roofline may be subject to local permitting requirements for safety purposes. Further, masts that extend beyond an exclusive use area may not be covered by this rule.
Q: Are all restrictions prohibited?
A: No. Clearly-defined, legitimate safety restrictions are permitted even if they impair installation, maintenance or use provided they are necessary to protect public safety and are no more burdensome than necessary to ensure safety. The safety reason for the restriction must be written in the text, preamble or legislative history of the restriction, or in a document that is readily available to antenna users, so that a person who wishes to install an antenna knows what restrictions apply. Safety restrictions cannot discriminate between objects that are comparable in size and weight and pose the same or a similar safety risk as the antenna that is being restricted. Examples of valid safety restrictions include fire codes preventing people from installing antennas on fire escapes; restrictions requiring that a person not place an antenna within a certain distance from a power line; and installation requirements that describe the proper method to secure an antenna.
Restrictions necessary for historic preservation also may be permitted even if they impair installation, maintenance or use of the antenna. To qualify for this exemption, the property may be any prehistoric or historic district, site, building, structure or object included in, or eligible for inclusion on, the National Register of Historic Places. In addition, restrictions necessary for historic preservation must be no more burdensome than necessary to accomplish the historic preservation goal. They also must be imposed and enforced in a non-discriminatory manner, as compared to other modern structures that are comparable in size and weight and to which local regulation would normally apply.
(Emphasis mine)
I understand this to mean that your local building code enforcement agency may require a permit above 12' (above your roofline), but they can't deny one because they 'don't like the look' or some other arbitrary reason. Also, notice that item (3) does not have a size restriction.
On my property, I read the FCC OTARD rule to mean that I can build a tower higher than the surrounding trees and terrain, hundreds of feet if necessary. As I pass 12 feet above my roofline, I may have to play nice with the local building inspector though.
Be sure to read the rest of the FCC information. There are cases that would limit your antenna height, if you live near an airport for example.
Last edited by GroundUrMast; 6-Jul-2012 at 5:59 PM. Reason: puncuation, tower example
