All questions and answers about broadcast tv reception and More.
The largest number of Tv stations and channels by far is the New Orleans group of Tv stations. 12 Tv stations are Strong and moderate signal strength , 4 Tv stations are weak signal strength.
The Baton Rouge group is 5 Strong to moderate signal strength and 5 weak signal strength.
The mature oak trees that are to the south east toward Orleans , is there a way to position a antenna to shoot around of to the side of the trees??
The mature oak trees , are there trees beyond the oak trees??
Could a antenna be set up on the other side of the oak trees??
Or are there more big trees beyond the oak trees that will reduce or block reception.
Darrens , it is time for you to think creatively , Now.
The best reception will be with the antenna above the trees.
It is also possible to cut a path through the trees.
Trees can be cut down.
It is also possible to shoot under the trees.
If the branches are to low , the branches can be cut.
