Thanks, it will take a couple of days to check out suggestions. Antenna is mounted on a pole at a roof peak; it clears remaining roof lines but there are trees some about 300 feet away.
There is only one TV. Sharp Aquos flat panel
Yes there is a Radio Shack amplifier which sems to be working fine. Had it for many years.
Will get a new transformer and see what happens. But if that was the problem, don't think the reception would be good on some channels and bad on others.
