Help getting started, antennas and such
Yep. Figured I would need to do an upgrade on the antenna. Appreciate the recommendation on " Winegard HD7694P or any of it's larger variations (7695 through 7698). " I'm assuming that bigger is better... meaning further range of receiving signal?
Regarding "The Antennas Direct CPA-19 preamp... " is this a separate component that I would need to purchase...or is it built into the antenna?
Thanks again.
