Old 4-Jul-2012, 3:41 AM   #4
Originally Posted by trcaw View Post
Here is the new TV Signal Analysis with 25' off the ground: http://www.tvfool.com/?option=com_wr...1349e3f49af99c
Maybe a dumb question but is there a way to mount the two antennas together?
Thanks, the signal conditions do improve. Particularly for real channel 8.
Not a dumb question at all. Here are examples of wall / gable mounts: http://www.3starinc.com/wall_mounts.html There are also 'eave' styles that would work well just above your garage roof or at the other end of the house.
Combined with a 10' mast, this style mounting system has plenty of room to mount one antenna at the top, the DB4e in this case, and the high-VHF about 4' below the top on the same mast. The antennas mounting clamp design allows you to mount to the mast at virtually any level.
http://www.3starinc.com/channel_mast...enna_mast.html
