I don't see a low VHF station within 100 miles except for several unbuilt LD CPs for religious broadcasters. I'd suggest saving the extra metal and sticking with a 7-51 antenna for whatever is available.
A DB8 on a rotor and with a pre-amp should do okay depending on your requirements. The only high-VHF stations on your chart are channels 7 & 8 that are currently analog-only and broadcast Spanish language programming. It's your call as to whether you want to try to get them.
