Originally Posted by signals unlimited
GUM, Is this a suggestion for two antennas? I see only the 7698P and a pre-amp.
and
Originally Posted by Hippie
A brief update. After much budget consideration (that is consulting the mrs.) I think the idea will be to start small but leave room to grow. So for now let's just say I am only interested in the colorado springs stations. If I aimed an HBU22 at the those stations and ran that into a single HDHR3, could I then, at a later date , add an HD7698P on the other side of the chimney, point it to the denver stations and add a second HDHR3?
And if that is the plan ultimately, is the HBU22 a good choice to start off with? Maybe a Winegard 7694?
Thank you again everyone. I'll be sure to keep you updated as this project progresses.
The HD7698P would be the antenna to try as a single antenna solution if trying for the Denver signals hoping for reception of the locals through the back. (A good idea IMO.)
@Hippie, If you're eventually going after the Denver signals, why not try the signal antenna solution. If it works, you skip spending money on a second antenna and HDHR. If the Denver signals are less than reliable with the 7698, turn it around at the locals and have more than enough signal.
Reason: Simplefy
