The HBU22 will work fine. Just aim toward the local stations and scan for antenna channels.
You should ground the coax. Order a ground block with the antenna. This will go in line with your coax. Use a #8 copper wire from that to your service ground. Or drive a 6" copper ground rod into the ground where the coax enters your home and attach the #8 copper from the block to that.
Yes you can add the other antenna at any time.
