Old 2-Jul-2012, 9:53 PM   #11
If you're going after the Denver signals, use the HD7698P and an Antennas Direct CPA-19 preamp.
I own both the HDHR3-US and the older HDHR-US Dual. Each provides two tuners in one chassis. However, to terminate two separate antennas will require two HDHR3-US units because they have only one antenna connection. The older design had separate connectors for each tuner.
http://forum.tvfool.com/showthread.php?t=820
