I prefer the 7698 however as Electron pointed out the Antennacraft has better ability to receive from the rear, so that may be your best bet.
With that being so you will not need the 751 or the HDTVo unless you fail to receive the strong locals from the rear of the Antennacraft antenna. If that fails then and only then add the 751 or HDTVo.
