Old 2-Jul-2012, 9:19 PM   #9
Hippie
Thank you, thank you, thank you. The response from the community here has blown me away. I think to start with I'm going to try a single antenna and just see if I can't get the Colo Spgs channels via the rear of the antenna. I can always add a 2nd antenna or a rotor later.
To start with then I need a single antenna. From what you have all said I think I'm basically down to:
Winegard HD7694P
Winegard HD7698P
Antennacraft HBU22 (which I didn't see on amazon, however there was an HBU44)
Terk HDTVo
RCA ANT751
Anyone have any thoughts on what would be best?
One other thought, while admittedly unfamiliar with the situation, I was thinking there may be a way to splice the signals from 2 different antennas together (ultimately then into a SiliconDust HDHR3-US, and then to a Windows Media Center box) . Is that possible? Or would I be required to run a/b switches (not ideal)
Hippie is offline   Reply With Quote
