DTV reception advise and systems design
Yes...To receive Denver stations use the HD7698P above your roof, aimed to 328 degrees magnetic. Just below the 7698 mount a Terk HDTVo or an RCA ANT751 antenna aimed to 191 degrees.
You will need to run seperate coax for both of these antennas and an A/B switch. Radio Shack sells an A/B switch that operated with a remote control. That will allow you to easily switch between your locals and the Denver stations.
If you are using multipul sets, you can install the A/B up-stream from the splitter, or you will need both coax and A/B switches at all locations.
Another way would be to use the HD7698 antenna and a rotor Channel Master 9215 rotor.
