A quick update:
Antenna #1 is UHF only and is pointed about 40 degrees towards the Victorville translator. Digital channels 47 (KCET) and 64 (KHIZ - Barstow) are a "lock" and are crystal clear. The remaining channels are analog, strong enough to have color and sound, but varying degrees of snow. Those include 21 (CBS), 25 (NBC), 27 (Fox), and 51 (MyTV).
Antenna #2 is VHF only and is pointed about 240 degrees towards Mount Wilson. Digital channels 7 (ABC), 11 (Fox), and 13 (MyTv) are a "lock" and are crystal clear. Channel 9 (KCAL) is in that direction also, but it has a weaker signal than the others, and I can't pick it up unless I start to go to extreme measures.
The Antennas Direct PA-18 amplifier and the UVSJ are mounted under the UHF antenna. The VHF antenna is about 8 feet away, that's the only spot on the roof to get the Mount Wilson channels!
That's as much effort as I'm going to put into this, being a vacation home and not my primary residence. At least I have all the major networks covered between the two antennas.
Thanks to all for your excellent advice. I'll write a blog post with more detailed info and photos later.
